Bilt Hamber auto wheel
Google is your Friend. ;)
What is the difference between Korrosol and Auto-Wheel?​
While these products are both intended to target the same brake dust and other metallic fallout, they are specifically formulated for their own particular job. Korrosol is designed for paintwork and will spread more easily across the surface, while Auto-Wheel is designed to cling on and work on a dirtier, verticle surface.
The products will be easier to use and it will be more economical for you if these products are used correctly, however, using these products interchangeably won’t cause damage.
Schrijf je reactie...
