vraag van een beginnende detailer
DB9
23 aug 2010
448
Beste forum leden,
Wil morgen m'n auto met de DJ supernatural verwennen en er 2 lagen sn op zetten. Hoelang zou ik moeten wachten voordat ik de 2de laag erop kan aanbrengen?
volgens de omschrijving op de dodo potten kan het met een uur maar beter is 12 uur te wachten,ook advies van dodo juice
Van de Dodo site:
question
What is layering? And what is the best technique?
Answer
Waxes like to go on thinly, because they cure better. This means that to improve durability and depth of shine, it is better to layer a wax, rather than trowelling it on an inch deep. After all, the wax in contact with the paint is all that can bond. the rest gets buffed off. With layering, the law of diminishing returns applies. So 2-3 is all you need; remember that the solvent in the new layer of wax can remove a little of the old layer. The main points are: 1) although you can layer immediately after buffing, it is advisable to leave at least 30 mins, to allow the wax to fully cure - or as long as 24 hours if the car is in a clean garage; 2) don't layer over old wax or wax that has been on a car for weeks as it will have degraded and you'll risk trapping dirt between the coats; 3) only use a compatible quick detailer between layers as they contain ingredients that could interfere with the wax - or use a water mist if you need to dust the bodywork.
Sjeessus, wat zijn jullie toch altijd weer snel met jullie antwoorden en hulp :-)^
Schrijf je reactie...
