Hoe dan ook, zeker lekkere glans!Dat is toch wanneer het droog is? Dat was bijna gelijk, minuut of 3. In een koele parkeergarage. Geldt deze methode dan ook voor deze Wax?Bekijk bijlage 171139
Zo is die uiteindelijk geworden.
1 | Prepare your car by carefully hand-washing it with a pH-neutral shampoo, drying it and decontaminating its surface using a clay bar, cleaner or other product of this kind. |
| 2 | Get a minimal amount of product on the pad by applying gentle pressure to the surface of the wax and moving the pad around in a can. |
| 3 | Spread a thin and even layer of wax on the paintwork in a cross-motion, working panel by panel. |
| 4 | Wait about 5-8 minutes until the wax binds with the paintwork. The higher temperature, the shorter time needed. |
| 5 | Polish the residue with a clean and dry microfiber cloth, frequently changing the sides of the microfiber or replacing it with a new one. Work until you achieve a satisfying effect. |
