Onlangs binnengekomen met een bestelling uit UK:
Autobrite Magifoam
Omschrijving volgens de webshop van Autobrite:
Ultra high foam additive for a stable dense foam.
Magifoam has been formulated to be a concentrated ultra high foam additive that will produce an extremely stable dense foam when used through a Heavy Duty foam lance. With a light banana scent this product is extremely pleasant to work with and the stable foam produced will linger for up to and over 30 minutes meaning that there is no more rushing around to clean wheels, badges or door shuts like before whilst the foam is dwelling. By using magifoam as a foam prewash the risk of swirl marks and scratches when washing the car is dramatically reduced.
- Superior, Safe Cleaning Action
- Very High Foaming
- Banana Scented
- Economical to use.
- Produces a blanket of foam on vehicle
- Dwells on car surface up to 30 minutes giving you maximum penetration and cleaning
- Contains biodegradable surfactants
- LSP safe
- Leaves a great finsh!
Usage Instruction;
Magifoam has been primarily formulated to be used in a foam lance, with a dilution rate of 100:1 it is also very economical, this equates to roughly 1-2" in the bottom of a 1l bottle in a foam lance when using with a domestic pressure washer.To use simply rinces car surface first, then spray the car with a liberal layer of foam and allow to dwell for at least 10 minutes, after this time simply rinse the foam off and watch the dirt rinse away too. The longer this product dwells the deeper it penetrates into the dirt and more of the dirt will then be removed.
Voordat ik begon, had ik al vernomen dat deze foam betere "standtijd" had wanneer deze opgebracht werd op een "droge" wagen.
Dus NIET voorspoelen voor het foamen...
Men neme:
- Een smerige VW Transporter T5 T-edition
- Nilfisk HD met Autobrite Foamlans
- +/- 100ml Magifoam, aangevuld met warm water tot +/- 500ml totaal in de fles
Gelijk bij het openen van de fles dacht ik, die bananen-geur is ver te zoeken... :weetniet
Ruik lichtelijk chemisch zelfs..?! :roll
Afijn, geur is niet zo belangrijk, dus naar buiten met t zooitje een foamen maar!
Zoals gezegd, de wagen dus NIET voorgespoeld, om een betere werking/standtijd te verkijgen...
Na twee seconden foamen kwam er een heerlijke geur me tegemoet vliegen, BANAAN! :ja
Dus wat dat betreft zit het wel goed met deze foam 8d
Maar nu verder met de belangrijke zaken...
Reinigende werking:
Lijkt me niets mis mee toch?
Verder nog op de koplamp een leuk "fenomeen"...
Who needs Poorboy's Bug Squash?
Hieronder een plaatje van de T5 na een dik kwartier:
Soortgelijk resultaat heb ik tot nu toe met de SSF nog niet behaald, terwijl ik daarbij ongeveer dezelfde dosering gebruik qua foam/water.
Andere factoren:
- Bus staat goed in de wax (Collinite 845 aan de zijkanten en achterkant, Zymöl Concours en Dodo SN op de neus en zijschermen)
- temperatuur was zo'n 18 graden, met een normale luchtvochtigheid.
- waxlaag werd (voor zover te beoordelen) inderdaad niet echt aangetast, beading en sheeting volop aanwezig na de foam-sessie!
Inmiddels te horen gekregen dat de batch foam waaruit deze komt, misschien niet goed geproduceert zou zijn, dus er komt nog een betere versie van 8-o
Dus.... 2 B continued...... _[]
Autobrite Magifoam
- Very High Foaming
- Banana Scented
- LSP safe
Usage Instruction;
Men neme:
Reinigende werking:
Andere factoren:
