Chemical Guys bekledingreinigers.
Citroën DS
27 mei 2008
119
62
Mijn CX heeft wat vlekken op het tapijt. Wie heeft ervaring met:
-Chemical Guys Lightning Fast Stain Extractor
-Chemical Guys Fabric Clean
Wat is het verschil tussen deze producten? Er staat geen uitleg over in de webshop.
Heb je wel zo'n product nodig als je reeds Poorboy's APC hebt?
Verdere benodigdheden voor het reinigen van de tapijten?
Je kunt ook even zoeken op de site van Chemical Guys, daar staat wel uitleg bij ;-)
Maar je kan toch gewoon APC van Meguiars gebruiken, dat gaat ook wel goed!
Over Fabric Clean
Fastest & Strongest spot and stain remover shampoo, breaks down and remove stubborn stains from any indoor or outdoor fabric,
upholstery or carpet safely and completely. FIBER CLEAN-Upholstery, Carpet, Fabric Superior Surface Shampoo is formulated from some of the most advanced cleaners and protectants.
fastest & strongest spot and stain remover shampoo
combines a superior biodegradable degreaser with a enzymatic odor eliminator for immediate odor control and long lasting, deep cleaning benefits of biotechnology.
naturally-occurring microbes in this product degrade the organic compounds that cause odor, eradicating them completely and leaving behind a fresh scent.
NO toxic chemicals, ammonia, bleach, color damaging detergent, or solvents,
fabric clean Cleaner removes stains fast and restores fabric, carpet and upholstery to like-new condition.
biodegradable formula removes oil, grease, dirt, coffee, tea,
juice, wine, and pet stains from any water-safe indoor and outdoor fabric.
20:1 dilution ratio VERY CONCENTRATED
Over Lightning Fast:
Just Spray and wipe off sports and stains on carpet , upholster fabric and just about anything.
the fastest and easiest to use carpet & upholstery, spot & stain remover
simply Spray-And-Wipe the stain is gone, never to return again
great for Automotive Carpet, upholstery and most fabrics
heavy duty fast and easy way to remove the toughest of stains
multi purpose cleaning ability
resists future stains
highly concentrated 20:1 dilution ration
Where To Use:
Auto Carpet
Upholstery
Headliners
Stained Fabrics
Door Panels
Stained plastics
Cars Boats RV's
Seats
Home carpet
Fabric
Home surfaces
Carpet and Upholstery, headliners and plastics are under constant abuse and are subject to stains and spills almost daily. Get to the problem fast and easy with Lightning fast!
Lightning Fast Spot and Stain extractor can be sprayed on and wiped off, it can be brushed in and vacuumed out or it can even be put into all leading extractor machines for superior results. Lightning Fast Carpet & Upholstery Cleaner is more then a cleaner. Lightning Fasts patented blend cleans without destroying color or fading surfaces. Lightning Fast’s water-based, hyper- concentrated formula is highly dilatable 20: 1 which means that 1 gallon will make up to 20 of useable products!
Lightning Fast contains powerful cleaning agents developed for professional detailers that need results fast. This uniquely designer blend of cleaners lift dirt particle away from the fibers so that they can be rapidly removed. Chemical Guys Premium Blend of surface protectants enable Lightning Fast to Protect carpet fibers after every use. Lightning Fast s unique water based surface protectant coating, shields carpet and fabric fiber to resist and repel future spots and stains by
Lightning fast works fast against even the toughest of stubborn stains. The unique emulsion lifts away contaminates while eliminating the need for vigorous scrubbing.
Lightning Fast can also be used for a large variety of
Just a though: It is always a good idea to use a odor eliminator and bacteria biller like So Fast after cleaning carpet. Odor eliminator rapids reduce foul Oder while elimination air born bacteria and lingers in carpet while laving a fresh scent.
Directions:
Vacuum area to remove any loose dirt and contamination.
Dilute Lightening Fast 1 part product to 20 parts water or as desired.
Spray Lightning Fast Carpet & Upholstery Cleaner on surface to be cleaned.
Allow to penetrate for 10-15 seconds.
Agitate gently with a brush or use a drill brush or Hook and Look brush.
Blot and wipe area dry with towel.
Once dry vacuum area to remove particles that may have loosened while cleaning.
Welnu, veel verschil lees ik toch zo niet. Beide zijn geconcentreerde tapijtreinigers, het eerste legt de klemtoon vooral op geurtjes, wat bij mij geen probleem is. Het andere op vlekken.
Mag je met Stain Extractor de ganse wagen doen? Of enkel waar het echt nodig is?
ik werk met de fabric clean en ben zeer tevreden over de resultaten.
op bekleding werkt dit beter als apc mijns inziens.
schuimt in de extractor niet.
sprayen met spraybottle, inborstelen indien nodig, schoonzuigen met de extractor is de beste methode.
ook handmatig met een doek werkt het erg goed en snel
Ik ook gebruik de fabric clean, top spul. Kan je mooi aanlengen, schuimt niet en werkt fijn. Zeker een aanrader, met de Lightning fast heb ik geen ervaring spijtig genoeg.
Inmiddels heb ik beide bussen in huis, van de Stain Extractor heb ik een verdunning van 1 op 20 gemaakt, van de Fabric Clean een verdunning 1 op 10 in een spuitbus, voor vlekken, en straks ook nog 1 op 20 in een drukspuit, goed voor de grotere oppervlakken.
Is 1 op 20 wel voldoende voor de Stain Extractor? Het ziet er vrij flets uit wat de kleur betreft. Hoe sterk verdunnen jullie het?
Nu heb ik ook nog de Mothers tapijtborstel gekocht , een van de dagen ga ik er aan beginnen.
Harold-A1 zei:
Nou toen ik Fabric Clean in een Numatic heb gedaan.. als schoonmaakmiddel begon het te schuimen, zo hard zelfs dat de Numatic overliep.
Dus weinig product gebruiken en dan heb je minder schuim.
Vandaag aan de slag met de Fabric Clean (1 op 20), de Mothers tapijtborstel, enkele oude handdoeken en de Dyson kruimelzuiger.
Opspuiten, inborstelen, laten inwerken, weer inborstelen, de handdoek rond de borstel wikkelen en droogwrijven daarmee. Er kwam veel vuil mee, maar wat wil je bij een auto van 32 jaar oud.
Daarnaa duchtig stofzuigen met de Dyson, en de achtertapijtjes zijn werkelijk weer als nieuw. Nu staat de Dyson op te laden, deze namiddag de voormatjes. Daar vermoed ik de Lightning Fast nodig te hebben.
Naspoelen is toch niet nodig? Daar wordt nergens over gesproken.
