Dodo Juice
Nieuws van het Dodo Juice front:
Pre-launch Supernatural Wash Sponges
Dododom zei:
We will launch them in Feb probably...
En voor de Dodo Juice leden op dit moment een aantrekkelijke aanbieding:
Dododom zei:
available as an exclusive to Dodo forum members
We have stock now but just not labels, so can't launch them. As a special Dodo forum deal I'll let you guys have some to play with at a special rate if you have a paypal account. These will retail for 9.95 GBP when launched as the Supernatural Wash Sponge, but if you paypal 8 GBP to us we'll let you have one with FREE carriage. That includes European and International Dodo forum members. Just pay the required sum to paypal -at - dodojuice - dot -com as the payee paypal email address and include your name and address in the details so I know where to send them.
As an aside, I have personally researched maybe 30-40 different mitts and sponges in the course of our search for products, and there is no right or wrong... it's what works for you. Here's a quick pros and cons of the major types of wash implement:
SPONGE
Pros - holds a lot of water, can be soft, you can see dirt on the surface to remove it, easy to maintain
Cons - can trap dirt on the surface, plus open cell foams allow dirt migration INTO the sponge; far from a good thing IMO, as it means the dirt can often pop out when you don't want it to mid-stroke and cause a mark (natural foams are open cell and also have the added danger of sand and coral particles within their mass, if wild and not farmed)
SYNTHETIC MITT
Pros - have pile so dirt can be migrated away from the paint surface; easy to maintain
Cons - if not checked or removed, dirt may migrate back to the surface unchecked; some mitts may not hold as much water as sponges etc; may not be as soft as you'd like
NATURAL MITT
Pros - have pile so dirt can migrate away
Cons - longer the pile, the more difficult maintenance can be, plus they can rot; dirt left in the pile may return to the surface; it can be difficult to remove ideeply held dirt during a wash, unlike a sponge
CHAMOIS
Pro - holds a lot of water, can be soft when wet
Cons - no pile, so dirt can be trapped against the surface
That's why we have things like the Basics wash pad, which performs well at a low price - it has soft pile, but it's not too deep, so a good compromise between the pile keeping dirt away and the difficulty therein of removing it or guarding against its unforeseen return. We then have the wookie, as the ultimate in pile length, but it is hard to maintain and needs combing... And the new ultra-soft 110ppi Supernatural Sponge, made from closed cell foam that's the softest on the market (passes CD test etc). Whilst it may trap dirt on the surface, you'll see it and it can't migrate into it that far. It also holds loads of water because the pores are so dense. Whilst in between, we have the Tribble Mitt for general duties (a classic sheepskin number) and the Captain Crevice for wheels (doesn't hold enough water for normal use, really, but some like it for bodywork, too).
Ik heb gisteren de basics of bling wash pad gebruikt, de kwaliteit viel me tijdens het wassen niet tegen..
Maar toen ie uit de was kwam des te meer..... kwaliteit niet echt des dodo's... ook niet voor die prijs... :weetniet
+1 Ivo, ik heb hem inmiddels ook gebruikt, vind de kwaliteit tegenvallen. De Bone blijft mijn favoriete micorvezel spons. De vorm was er aardig uit na de 30 graden was, terwijl mijn Bone al wel 4 jaar oud is en er nog steeds uit ziet als nieuw. Het eerste DJ product die ik vind tegenvallen.
Heb het idee dat die rebranded "snel in productie genomen" producten van Dodo sowieso niet echt van de alom bekende "Dodo kwaliteit" is.
Thanks Patrick voor de tip van de SN sponge...... is zien of dat wat is :-)^
Wordt die SN sponge nou een 'echte' spons in de trant van een Zymöl spons (dus niet met microvezel eromheen)?
Op detailingworld zie ik wel veel mensen die zulke sponzen gebruiken in combinatie met ONR (Optimum No Rinse).
Voor gebruik met een 'gewone' shampoo zou ik toch microvezel producten blijven gebruiken.
Wat ik er van begrijp is het 1 blok wat bestaat uit "ultra-soft 110ppi". Dit is volgens mij gewoon foam wat ook gebrukt wordt bij de SN fingermits ??
Misschien iemand een foto ergens gevonden?
Zojuist de Clearly Menthol gebruik.
Werkt i.m.o. net zo fijn als de Meg's GCC, maar ruikt een stuk prettiger. Na het foamen van de auto zat door de sterke wind het hele keukenraam vol foamvlekken. De Clearly Menthol op een badstofpad gespoten en het raam in lekker willekeurige bewegingen schoon geveegd. Vervolgens met een MF-ramendoek van onbekend merk het raam drooggeveegd en geen streep of vlek meer te bekennen :-)^
Iemand enig idee of het ook op getinte ramen gebruikt kan worden?
