Meguiar's 2012 Nieuwe en verbeterde producten.
Dibbuz
Bastard of Bling
Medewerker
6 apr 2008
7.643
198
45
Of alles ook naar Europa komt is nog maar de vraag maar dit zijn de nieuwe en verbeterde producten van Meguiar's voor 2012:
Consumentenlijn
Perfect Clarity Glass Cleaner
•Professional grade glass cleaner
•Can be used in the sun
•Glass stays cleaner longer with dust repellent technology
•Leaves behind streak-free "Perfect Clarity" glass - Clarity you can see!
•Unique chemistry contains lubricants that create an easy slide effect with no residue
Nieuwe glasreiniger, gaat waarschijnlijk de NXT Glass Cleaner op termijn vervangen.
Ultimate Wash & Wax Anywhere
Product attributes:
•Safely cleans more "dirt" than a spray detailer, AND leaves hydrophobic wax protection!
•1 bottle will do 3 - 5 average cars
•The solution to "I want to wash my car, but..."
•"I don't have access to a hose."
•"it's winter.:
•"my city is under water restrictions."
•"I live in an apartment."
•This is the solution for consumers who don't have the space to do a traditional wash, as well as enthusiasts who need something more than a detailer
Hot Rims Brake Dust Barrier
Product attributes:
•Truly lasts on wheels
•Works on painted, chrome and polished aluminum wheels
•Makes wheels easier to clean
•Outperforms existing wheel protectants
Rubbing & Polishing Compound
(nieuwe verpakking, is nu in blikvorm)
Product attributes:
•Rubbing compound: Removes heavy oxidation
•Polishing compound: Removes light swirls & adds gloss ("clarity")
•Clear coat safe
•Non-scratching
•Same formula as tubs, which are being discontinued
Gold Class Premium Quik Detailer
Product attributes:
•It's all about the gloss!
•Delivers a dark, super glossy finish
•Makes black cars blacker!
•Delivers same cleaning ability as our other detailers
Gold Class Carnauba Plus Quik Wax
Product attributes:
•Delivers a deep, rich, more traditional wax finish
•Tactile evidence of the “wax” protection that’s left behind
•Non-whitening on trim
•Can be applied in full sun
Quik Wax: New & Improved Formula
Product attributes:
•New formula leapfrogs competitive products
•True "wax-as-you-dry" formula
•Instant gratification: Great looking results!
Hot Rims All Wheel & Tire Cleaner
New & Improved
Product attributes:
•Reformulated to clean wheels and tires
•Safe on all factory coated wheels
•Visually see dirt leaving the wheel & tire
•Increased foaming action
***geen plaatje***
Product Attributes:
•Helps maintain headlight clarity for new & recently restored headlights
•Provides durable protection from harmful and damaging UV rays
Headlight Protectant
DynaCone Pad Cleaner
Product attributes:
•Safe on the DynaCone and other metal polishing pads
•Fast-acting surfactants dissolves away metal polishing grime
•Replenishment for the cleaner in the Wheel Polishing Kit
***geen plaatje***
Meguiar's PowerSystem
Product attributes:
•Utilize this conventional, non-threatening tool to power a proprietary, patented, dual-action attachment
•More than a wax applicator - Provides a platform for multi-function applications
•More than a polisher - A platform that allows tremendous versatility serving multiple applications
•Using any corded drill, the forced rotation movement allows for safe and effective defect correction
Opzetstuk voor boormachines met Dual Action functie!
Detailerlijn:L
eather Cleaner
Product attributes:
–Removes tough stains
–Non-staining formula quickly cleans leather
–Restores “like new” look
–Colorless with a pleasant citrus fragrance
–Less aggressive than APC
–RTU
–More thorough cleaning that D180
***geen plaatje***
Synthetic X Press Liquid Wax
Product attributes:
•Wipe on & off
•Long lasting hydrophobic protection
•Deep Dark Wet Shine
•No dusting
•Can be applied to wet or dry car
•Hand/DA application
Rinse Free Express Wash
Product attributes:
•​Exterior / Interior Wash -128:1 (1 ounce / gallon)
•Cleans all vehicle surfaces
•Non-scratch, non-streaking formula
•Paintable / contains no silicones
•Biodegradable
***geen plaatje***
Tire & Trim Gel
Product attributes:
•Provides deep satin black look
•Thick consistency, no runs or drips
•Non-streaking formula
•VOC Compliant
•No oily residue left behind (Dries dry to the touch)
***geen plaatje***
Marine lijn:
Teak Cleaner
Product attributes:
•Quikly cleans and brightens teak
•Spray on, brush & hose off
•Biodegradable
Clear Plastic & Vinyl Window Wax
Product attributes:
•Cleans and protects vinyl windows and other clear plastics
•Provides UV protection
•Great for colored plastics
Flagship Ultimate Quik Wax
Product attributes:
•Mist on, wipe off...
•Can be applied in direct sunlight
•Marine’s longest lasting protection from a spray wax
•No white residue!
•Contains Hydrophobic Polymer Technology
M91 Power Cut Compound
Formulation Change For 2012
Product attributes:
•Updated abrasive technology boost cutting power and efficiency
•New enriched polishing oils allow for heavy oxidation removal with low product 'flash'
•Easy, smooth buffing with low product splatter and dusting
•Low swirl finish with no scouring
Meguiar's PowerSystem nu eindelijk het systeem voor mijn accuboormachine?
Ben benieuwd wat de mogelijkheden zijn en de prijs natuurlijk!
Ik ben benieuwd naar de Hot rims Brake Dust Barrier.
Wanneer in 2012 komen de producten binnen?
Ik ben wel benieuwd naar die glass cleaner.
Ik ben begonnen met NXT glass cleaner waar ik best tevreden mee was. Ik heb nu de DODO glass cleaner en persoonlijk vind ik de DODO net een tandje beter qua duurzaamheid.
Ik verwacht dat Meguiars meer heeft veranderd dan de sticker op de fles alleen dus ik ben wel nieuwsgierig :ja
Ik ben net een order aan het samenstellen, maar ik kan de slide lock detailbrush van Meg's niet meer vinden...
Ook al wat steekwoorden in de zoekmachine gegooid, maar dat bied geen uitkomst.
Kijk of zoek ik verkeerd, of zijn ze er gewoon niet meer?
Naadje, triple duty brush is er ook al niet meer, zjin beide hele toch wel musthaves.
Die blauwe heb ik eens beet gehad, maar kan mij niet echt bekoren, maar top dat je ff meedenkt.:-)^
Aficior zei:
Zitten duidelijk niet stil bij Meguiar's . Daar kunnen volgens mij de anderen nog een flink puntje aan zuigen.
ik ben begonnen met meguiars, en ben er stiekem nog steeds fan fan(spijtig genoeg zijn ze zo prijzig :auw ) maar ik vind hun lijn ook te groot en te varierend.
toen ik carclean ontdekte heb ik van dodo een flesje tropical mist gekocht(2jaar geleden), prima spul(echt PRIMA) en dit is nog steeds te krijgen...bij meguiars koop je dit jaar een PRIMA product...en het jaar daarop is het er niet meer of vervangen door iets wat net niet de stempel PRIMA kan dragen(kan van kleine persoonlijke dingen afhangen he, een geur die net anders is, een sprayfles die net niet zo perfect in je hand ligt, een detailer die toch nog een streep achterliet terwijl die van vorig jaar dat zeker niet deed....)
dus ze zitten niet stil, maar of dit als consument met maar 2a3 auto's om te onderhouden zo goed is?(je gebruikt geen 500ml fles detailer op een jaar op he...) ik betwijfel het!
en idd het boormachienetooltje ziet er leuk uit, maar er staat in e beschrijving wel dat het op een machine MET DRAAD moet he... dus wss heeft je accu machine niet genoeg power?
Is een heel andere borstel. De SLB is ideaal om randen bij rubbers ed met APC in te werken.
Bovenstaand borsteltje is meer om bijv. ventilatieroosters en randjes in het interieur stofvrij te vegen.
Heb beide in de tas zitten en zijn mi onmisbaar.
Van de SLB heb ik er gelukkig nog een aantal liggen als voorraad.
Meteen ingeslagen toen ik hoorde dat ze niet meer zouden komen (evenals de triple duty brush).
