We are proud to announce the launch of 5 new International specific products.
These products are only available outside North America. They are packaged, labeled and designed specifically for that reason. If and when these become available to purchase in North America, we will certainly announce it here on MOL
Smooth Surface Clay Bar Replacement
For enthusiasts who already have the Smooth Surface Clay Kit and want the convenience of purchasing just the clay bar, we offer the Smooth Surface Clay Bar Replacement. Removing above surface bonded contaminants and restoring a smooth surface to your paint finish is easily accomplished by using Smooth Surface Clay Bar. Our non-abrasive clay bar safely, easily and instantly removes bonded contaminants as you rub it across the surface of your car using a mist & wipe product, like Quik Detailer® as a lubricant.
Engine Clean
Engine Clean is the enthusiast’s choice for safe, effective and easy engine cleaning. The fresh smelling, biodegradable formula quickly lifts away dirt, grime and grease to clean even the hardest-to-reach under-hood areas. Safe on rubber and plastic and guaranteed not to degrade fittings or hoses, Engine Clean is the easy way to leave your engine bay looking just detailed.
Engine Dressing
Engine Dressing is the safe, easy-to-use solution to keep the variety of materials used on and around engines looking their best. The non-greasy formula leaves a deep, rich appearance while providing long-lasting protection on plastics, rubber and hoses. Protect, preserve and enhance everything under your vehicle’s hood with Engine Dressing.
Convertible & Cabriolet Cleaner
Convertible & Cabriolet Cleaner provides quick, effective and easy cleaning of all canvas, cloth, mohair and vinyl tops. This dedicated cleaner safely removes contaminants and stubborn stains like hard water, bird droppings and oil without drying out convertible tops. Convertible & Cabriolet Cleaner cleans mildew stains and leaves a brightened, like-new appearance to ensure that your convertible top looks its best.
Convertible & Cabriolet Weatherproofer
Protect and preserve your convertible top with Convertible & Cabriolet Weatherproofer. This comprehensive formula creates a protective barrier that delivers long-lasting defense against UV rays, acid rain, bird droppings, stains and more. Specially developed for use on canvas, cloth, mohair and vinyl tops, Convertible & Cabriolet Weatherproofer is the easy-to-use solution to keep your convertible top looking like-new.
Tim,
Wanneer kunnen we een en ander verwachten? Zitten leuke produkten tussen
Engine Clean
Engine Dressing
Tim,
