Welke wax na pb sealant met carnauba?
Tja... lastig.... het is een sealant met Carnauba ingredienten voor de extra glans, vond net een leuk artikel over waxen en sealants (helaas in het Engels):
Wax or Sealant?
Which should you choose...
You have two basic choices when it comes to paint protection: carnauba or synthetic. Both have their good points, and the choice is really all about personal preference.
Carnauba wax is the preferred wax of collectors and automotive enthusiasts because it creates a rich, warm glow. It doesn’t appear to sit on the paint. It transforms the paint into a deep, liquid pool that shimmers under changing light conditions. The more carnauba, the more shine. The wax is produced by the Brazilian Tree of Life in order to coat its leaves. The wax provides protection from the sweltering sun and it sheds water so it falls onto the ground and is absorbed by the tree’s roots. If you think back to junior high science class, you might remember that plants absorb oxygen through their leaves. For this reason, carnauba wax is breathable. Good for the tree and good for your paint.
Carnauba is rock hard in its natural form. When the leaves of the Tree of Life are harvested, the wax flakes off as the leaves dry out, or they are put into a machine that removes the wax. It comes off in hard flakes. Wax makers have to blend the wax with oils, petroleum distillates, or a solvent called naptha (commonly used to thin wood varnishes and paints) in order to make the wax workable. The very best carnauba-based wax is only about 1/3 natural carnauba. It’s probably for the best since the price gets higher and higher as the concentration of carnauba rises. When a product advertises “pure carnauba wax” or “100% carnauba wax”, they are referring to the purity of the carnauba that is in the product, not the product as a whole.
That brings us to grading. Carnauba is harvested and then graded according to color, purity, and where it was grown. Trees grown in the northern area of Brazil produce the highest grade carnauba. The yellow wax is the most pure and therefore receives the highest grade. This is the grade most commonly used in high end car waxes and in the pharmaceutical industry. (They coat pills in it so they go down easier.) Some manufacturers refine the yellow wax again into an ultra-pure white wax.
As you’ve already read, carnauba protects the leaves of a certain palm tree from the intense heat and humidity experienced in Brazil. The wax repels water and, consequently, most contaminants. When applied to any surface, carnauba retains these characteristics. Therefore, an application of a carnauba-based wax to your vehicle will protect it from UV rays, heat, moisture, oxidation, and environmental contamination. And it looks like a million bucks!
The drawback of carnauba, if you can call it a drawback, is that it does not last as long as a synthetic sealant. A carnauba finish will wear off in approximately 6 to 8 weeks. It depends heavily on the climate in which you live and whether or not your vehicle is garaged. Daily commutes in a hot, humid climate mean a shorter life span for your carnauba coat.
In a nutshell, carnauba wax is the wax of enthusiasts. It appeals to people who want the absolute most stunning shine available and are willing to spend a couple of hours every month or so to get it. Most of them will tell you it is time well spent.
Paint sealants are kind of the anti-carnauba. They last a lot longer, they are easy to apply, and there’s nothing natural about them. This is surface science at its best. A paint sealant is made of polymers, which are composed of tens of thousands of synthetic particles that are linked together. When a sealant bonds to your vehicle’s paint, it forms a rigid shell. It is not the warm carnauba that seems to melt into the paint. Paint sealants sit on top of the paint like a transparent chain metal suit. They are glossy and slick, but they do not have the warmth and depth of a carnauba.
Paint sealants have gotten progressively more popular as time goes on. Some people really love the hard-as-glass look. In an industry that is driven by technology, it seems appropriate that an engineered paint protector is the new favorite among the younger generation of detailers.
However, the real selling point of a paint sealant is the durability. A premium paint sealant can last 4 to 6 months, sometimes longer. By “last”, I mean that water will continue to bead and the paint will remain protected from UV rays and contamination. For people that spend more time driving than detailing, the paint sealant may be the way to go.
Paint sealants are extremely easy to apply. They are always in liquid form and they spread easily by hand or with a polisher. This time-saving feature makes paint sealants an attractive choice for those who like instant gratification, and who doesn’t?
As you’ve seen, there are a lot of differences between paint sealants and natural carnauba waxes. Glassy, hard shell or deep, liquid shine? Six months or six weeks? These are the basic questions you have to answer before selecting your paint protection. However, a growing number of enthusiasts simply refuse to choose. Instead, they coat their vehicles with a layer of sealant for long-lasting protection and then top it with a layer of carnauba for the dazzling shine. Even if you forget to reapply carnauba in 6 weeks, your paint won’t suffer. It’s the perfect marriage of beauty and longevity!
Remember, paint protection is one of your vehicle’s basic necessities.
leuk stukje inderdaad!
toch zelf ook maar eens kijken naar een sealant (om te kijken of het verschil in diepte e.d. ECHT te zien is)
aangezien fk1000p niet een ECHTE sealant is
Ik las laatst in een topic op DW (Detailing World) een reactie van Dom of PJ van Dodo Juice over het verschil tussen carnauba waxen en synthetische sealants. Hier bleek uit op te maken dat tegenwoordig de grens tussen wax en sealant niet zo scherp meer te trekken is. Veel carnauba waxen hebben ingredienten van een sealant en ook andersom.
Hier op het forum zie je ook al regelmatig wat 'half-om-half' producten uit dit grijze gebied. Fuzion lijkt me wel het bekendste voorbeeld. Bij mijn weten is de Collinite 845 ook zo'n hybride. En wat dacht je van de nieuwe Purple Haze Pro?
Toch zeker niet de minste producten zou je denken.
De Collinite 845 is een Carnauba wax en wordt ook wel eens een sealant genoemd, maar dat is, net zoals bij de FK1000p (FK = Finish Kare ;) Weer afkorting..), dus geen sealant, maar door hun lange duurzaamheid worden ze daarmee wel eens terecht of onterecht onder de sealants genoemd
Ik denk ook dat de grenzen steeds meer vervagen, ook gezien de snelle ontwikkelingen op wax en sealant gebied.
het gaat inderdaad allemaal razendsnel..
wel leuk..
ook heb ik niet zolang geleden gelezen, dat geen enkele wax, transparant is, en zou het beschermen van de lak (met een wax of sealant) altijd een minder resultaat laten als dat je er niets op smeert..
ik denk dat van dat oogpunt ook de stelling: als de voorbereiding goed is, ziet hij er ook bescherm goed uit! hieruit voortgekomen is!
en de afkorting fk1000p staat voor finish kare high temp synthetic paste wax geloof ik..
niet echt heel belangrijk, aangezien deze toch niet bij carclean tekoop is (en zoiezo niet in nl geleverd wordt) (nog niet!)
Ik ben nu een jaar met detailen bezig en nog niet zo heel ervaren.Moet wel zeggen dat de pb sealant met carnauba altijd een super resultaat heeft opgeleverd.Dit lag ook grotendeels aan de goede voorbereiding.
Als de pb sealant op is vervang ik hem door de 845 om eens wat anders te proberen.Vandaar mijn verlanglijstje.
Bedankt voor de info :-)^
Even nog wat links hierover (een wat lang verhaal over sealants vs. waxen, dus ga niet alles knippen+plakken)
Dit is het topic
En expliciet het bericht uit dit topic dat ik bedoelde.
Ik heb afgelopen weekend trouwens de 845 geprobeerd op mijn motorkap. Ziet er na het nodige schudden nog steeds uit als een soort rare smurrie, maar is goed aan te brengen en geeft splendid resultaat.
eerste keer in warm water zetten, zodat hij zo dun als water word..
de keren daarna is het heel ff schudden, en weer zo dun als water..
die van mij is trouwens gevallen, dus nog maar half vol.. kwam ik gister achter:-"
