Ik kwam nieuwe pads tegen
De Lake Country hi-gloss CCS pads
Citaat over de pads:
This new, patented, Constant Pressure technology uses a layer of engineered, instant rebound foam between the pad and the backing plate to absorb off-axis movements while keeping the pressure of the pad on the surface constant.
The other patented, innovation incorporated in CCS Pads are a curved outer edge. The curvature on the outer edge of the pad allows easy transitions over seams and inclines.
Standard CCS pads are flat-cut. We pay extra to have the top edge rounded over because it prevents pads from snagging while polishing seams and edges.
We also pay attention to the back of the pad. Standard CCS pads run the Hook and Backing material to the edge of the pad. This material is very course and can cause scratching if it hits the paint while working in tight spaces or around mirrors and wings. We cut the Velcro brand fastening material back 1/4 inch from the edge and 1/8 inch into he pad. This allows you to work right against corners, mirrors, wings and complex angles without fear of scratching the paintwork
Misschien neem ik er een paar uit de USA mee.
Uitproberen zal wel na de winter worden.
